The fun never ends: CODE 614B...what do I do?
AlanS
Been thanked: 2 times
Post by AlanS »
2006 xc70 170K. CEL went on. My scanner says: 614B Camshaft Control, Exhaust, Faulty. I cleared the code, drove 170 miles, CEL went on with same code. I did some 'googling' to find these possibilities:
Low oil pressure
Poor oil quality
Damaged reset valve
Mechanical fault in the variable valve timing (VVT) unit.
The oil is spot on, recent change about 1K ago. Mobil 1 as usual. How would I check the other factors? I am a DIY-er....I can fix most anything IF I KNOW WHAT IS WRONG! Any input?
Has thanked: 2205 times
Been thanked: 1852 times
What oil viscosity are you using?
Neil
xanthefin
Year and Model: 1997 850
Has thanked: 106 times
Been thanked: 130 times
Post by xanthefin »
What values shows up for camshaft if you can look them?
Krons
Year and Model: 08S60 05XC90 02S60
Has thanked: 198 times
Been thanked: 215 times
Post by Krons »
Exhaust side camshaft solenoid may be gummed up. You can take it apart and attempt cleaning it, most just replace it.
08 C702.5T (sold)
The non-Swedes:
jonesg
Year and Model: 2004 V70
Has thanked: 73 times
Been thanked: 534 times
Post by jonesg »
vida can run a solenoid reaction test, if it reacts slow to throttle commands look to the oil pressure,
new oil and filter fixed mine.
