💥Just replaced C30 Auto Trans Shifter Blind...Now No Geartronic
anacortesian
Year and Model: 2009 c30
Post by anacortesian »
Replaced my 2009 c30 auto trans shift blind. Not a fun job. The old blind was broken into pieces and the old magnet was never found. Cleaned up the broken pieces and purchased a genuine volvo blind...genuine Volvo part (made in Germany) I paid more for it to avoid a cheap Chinese part.
Took plenty of time on replacing. Positioned just as shown below (smooth side up, ribbed side down). I think the slider with the magnet can only go into the blind one way. I never disconnected the shifter top circuit board as there was room enough to simply move it out of the way. Seems to me everything was reassembled correctly. The shifter shifts smoothly, all lights on the faceplate I notice that the white shift indicator lights for illuminating for P,R,N,D, and +M- light when the key is turned on. The small red indicator lights work with P,R,N,D as selected...but there is no red indicator when shift moves to the right to select +M- (and of course no geartronic). I am wondering if the shift blind magnet may be causing this? or if it may be a bad control board? Or even if the blind magnet may be inserted in the blind body incorrectly (from the manufacturer) ...possibly reversing the magnets polarity.
I'm at a loss here... If anyone has had this issue... can you let me know what fixed it?
Any help greatly appreciated.
shift plate diagram.jpg (21.38 KiB) Viewed 2867 times
MoVolvos
Has thanked: 312 times
Been thanked: 525 times
Post by MoVolvos »
Though the 09 C30 shifter differs from the 12 XC90 they should basically have the same type of system for the shifter. Our C30 T5 is a M66 so guessing about your issue.
In repairing the shifter lever I became acquainted with all the parts. If the system principles are the same then here is the part that's responsible for the Geartronics. Check your wiring and cables (if any). For the XC90 once in Drive the cable doesn't move fore or aft when you slide to Geartronics so it's up to the sensors in the board. Can purchase the shifter panel with the circuit board or without. The circuit board is lengthy.
Hope I am discussing the problem you are encountering.
viewtopic.php?p=646002&hilit=2012+xc90+shifter#p646002
2 Photos below Courtesy of Erie Volvo
https://www.ebay.com/itm/184000132159
Automatic Transmission Shift Indicator
Part Number: 31259587
Supersession(s): 30759919
https://www.volvopartswebstore.com/prod ... 59587.html
Panel. Gear Selector Passenger Compartment. Without Circuit Board. Without Circuit Card.
https://www.volvopartswebstore.com/prod ... 87938.html
XC90 Shifter Geartronic Cable.png (1.33 MiB) Viewed 2940 times
anacortesian
Thanks BKM.
Seems that purchasing the used unit from Erie may be the easiest solution. If it's a basic (and simple) bolt on unit.
anacortesian
**********UPDATE TO THIS POST: ***************
I notice that the white shift indicator lights for illuminate for PR,N,D, and +M- when the key is turned on. The red indicator lights work with P,R,N,D as selected...but there is no red indicator when shift moves to select +M- (and of course no geartronic). I am wondering if the shift blind magnet may be causing this or if it may the control board?
Anyone had this particular issue?
MoVolvos
Post by MoVolvos »
anacortesian wrote: 04 Jul 2024, 13:19 **********UPDATE TO THIS POST: ***************
Is there something here that might help?
New post Geartronic/shifter sensor location?
viewtopic.php?t=98105
anacortesian
Thanks for your response once again BKM. viewtopic.php?t=98105 ...poor guy...he is in the same situation as me. He's not sure where to turn now either. But, you know, if necessary, he and I may just have to purchase that Erie Volvo parts complete (used) shifter on ebay ($95.00). The guy has several available and has sold several and guarantees they are tested. Can't beat the price. Just seems a shame to have to replace the entire shifter assembly to fix this issue. But being stubborn Polish, I will tear into the beast one more time before I have to replace the entire assembly...I'll keep you informed.
MoVolvos
Post by MoVolvos »
anacortesian wrote: 04 Jul 2024, 14:54 Thanks for your response once again BKM. viewtopic.php?t=98105 ...poor guy...he is in the same situation as me. He's not sure where to turn now either. But, you know, if necessary, he and I may just have to purchase that Erie Volvo parts complete (used) shifter on ebay ($95.00). The guy has several available and has sold several and guarantees they are tested. Can't beat the price. Just seems a shame to have to replace the entire shifter assembly to fix this issue. But being stubborn Polish, I will tear into the beast one more time before I have to replace the entire assembly...I'll keep you informed.
MVS member Jonesroaddid did managed to get his to work however so give it one more shot. I'm older and have always been use to trying to fix or fabricate something first rather than taking the easy and disposable way out to remedy a problem.
anacortesian
Yes I'm the same way. I always try to reinvent the wheel. So asap I will pull the confounded thing apart again and see if I can get lucky. I will post if I do. Please say a good Act Of Contrition for me if you get a chance.
Anacortesian
PuppetMaster
Year and Model: Volvo C30 2008
Post by PuppetMaster »
I think you have to turn the magnet in the new shutter blind to change +/- polarisation
anacortesian
Well this is a genuine Volvo part, made in Germany as a matter of fact, so I felt assured that this would be an easy install. And although you may have a very good point, I'm not sure I understand what you mean by "turn the magnet" ...do you mean physically remove the magnet from it's holder and turn it 360 degrees...then reset it in it's holder? Please do explain.
