Where can I get a safe copy of VADIS and a working DICE cable, even if it is a Chinese clone? Check engine light is on with no engine problems.
Also, all the power windows on the driver side won't work. Tried to look at the cables for wire fraying but can't get the panel off, as it's different from the ones I see in videos. There is electronic response that can be heard when buttons pressed, but no physical response so I'm not sure the cables are frayed. Checked fuses for the windows and they are fine.
Thank you for any assistance.
Where can I get a VADIS and DICE cable and power window issue
UgDriveCar
- Year and Model: 2009 S80
Crap, I meant to say VDASH. Where can I get a safe copy of VDASH?
- Twarr12000
- Year and Model: 1999 S70 GLT
- Has thanked: 35 times
- Been thanked: 19 times
You can download VDASH from D5T5 free -
https://d5t5.com/
They also sell cables that work with VDASH. But be aware - it’s a “pay as you go” model
You can buy or download VIDA 2014D (the older ‘offline’ version from various places.
The official VIDA is free to download from Volvo but it has steep subscription pricing and you will need a genuine DICE interface
https://www.volvotechinfo.com/vida
If you just need to read DTC’s, you might consider a Volvo-specific scanner like the Foxwell NT510
https://www.amazon.com/FOXWELL-NT510-El ... d_source=1
(Use the Amazon link here on MVS if you buy the Foxwell)
https://d5t5.com/
UgDriveCar
Will the older VIDA work with the Chinese DICE cables from Ebay?
- Twarr12000
Some of them will. My experience has been hit/miss. The 2014 so-called offline version of VIDA doesn’t check to see if the DICE unit is genuine.
UgDriveCar
Been looking everywhere for the VIDA 2014 download, where is a good source?
- xiaofei204716
- Year and Model: XC90
- Been thanked: 2 times
To get your CEM PIN yourself is simple, contact me.
I'll give you the code in a minute. No VIDA required
- 3258 Views
Last post by packetfire
- 1255 Views
Last post by azureblue
- 3094 Views
Last post by matthew1
- 13 Replies
- 4513 Views
Last post by mecheng
- 16563 Views
Last post by xiaofei204716
