2011 XC70 Overnight dead battery with no Alarm Module
Third generation Volvo V70 wagon and XC70, and second generation S80. Are you an owner? Prospective owner? Get in here and join us! Start a new topic or comment on an existing thread.
2008-2016 V70
2008-2016 XC70
2007-2016 S80
davewave365
Year and Model: 2011 XC70
Been thanked: 2 times
Post by davewave365 »
I have a 2011 XC 70 that randomly goes dead overnight. I found it once with the flashers on, so I assumed it was a bad siren module. I pulled the module from the wheel well. It still randomly goes dead.
Strangely when I hooked it up to the charger, the horn started blowing, which I assume was caused by the door being opened to pop the hood. I assumed the alarm would be inop due to the missing siren.
I don't need an alarm.
Any ideas what the issue might be?
Thanks!
AVOIT17
Year and Model: 2009 XC90 RD
Has thanked: 6 times
Been thanked: 16 times
Post by AVOIT17 »
This has happened to me as well 3 times with an 2009 XC90 and once with a 2011 XC70.
Since these events are unusual/intermittent they are very difficult to diagnose if not impossible.
If this happens regularly you may want to measure the 'parasitic draw' on your battery to see if it is beyond normal. If it is, then there is a method to determine the source of the unwanted drain.
Google on YouTube "Parasitic Draw"
davewave365
Found it. Sirrus XM stuck on update. Known issue, there is a TSB/lawsuit in the works. Pulled the power plug and installed shunt so the radio still works. Volvo part # 8688083.
