i have 2006 Ocean Race XC90 that just recently had the radiator replaced . Now the coolant fan stays on and temp gauge is inop . Both will work properly if I start the vehicle and its under 32 degrees Fahrenheit . However once I get to my location and turn the vehicle of and back on the coolant fan starts running and the temperature gauge stops working again. The A/C also stopped working after the radiator replacement . I checked refrigerant and it is full .
Any Ideas?
Replaced Radiator now coolant fan stays on and temp gauge inop
georgedoyle
- Year and Model: 2021 Volvo XC40
I think the temperature gauge issue could be caused by a faulty coolant temperature sensor. This sensor is responsible for sending temperature readings to the gauge on the dashboard. If it's malfunctioning, it may not provide accurate readings or may not work at all. Replacing the coolant temperature sensor could potentially resolve this issue.
- Roger_850T
- Year and Model: 854T 1995
- Been thanked: 26 times
Since this just started happening when you had the radiator replaced, it seems likely that something was reassembled incorrectly. Perhaps a temp sensor not plugged in, or needs to be re-seated, or something like that. (I'd have to check to see if "fan on" is a fail-safe if the temp sensor fails. Seems plausible, but it's a guess.)
Any codes or CEL?
Roger
Any codes or CEL?
Roger
11 XC60 137k
08 V50 Project... Still in pieces
05 XC90 V8 213k
95 854T 350k Still my favorite daily driver
02 V70 186k+ Gave to my daughter, still going strong
03 S80 111k (crashed, but driver walked away unhurt)
93 945T 217k (gone to be parted out)
87 245 300k+ sold, still going afaik
84 264 Diesel, RIP at 160k
78 242 manual everything.
73 P1800ES, fun until the rust set in...
05 XC90 V8 213k
- 1593 Views
Last post by whilst
- 18 Replies
- 7213 Views
- 1136 Views
Last post by Stu70
- 2048 Views
Last post by precopster
- 1713 Views
Last post by FunkadelicxS40
