Good morning,
I just purchased this 2006 XC90 with the V8 and I have the SRS light on. The iCarsoft won't clear the code, I'm getting SRS-00E7. I'm getting 12.2V on the battery with car off. Using the iCarsoft it's telling me that the Voltage Supply to the SRS is 10.85 volts. I'm thinking this is the problem. the nut under the seat was loose and I tightened it until it clicked but that wasn't the issue. Should I replace my battery?
Thank you,
2006 xc90 SRS light on-iCarsoft 2.0 won't clear code
aaron1611
- Year and Model: 2006 XC90 V8
- Has thanked: 2 times
- Been thanked: 5 times
2005 Volvo XC90 V8
2006 Volvo XC90 V8
91 240 Wagon 5 speed 211K daughters daily driver sold
2013 XC90 wife's daily driver 201K
06 XC90 175K sold
02 V70 XC 135K sold
05 XC90 251K sold
Volvo's that were driven and flipped:
92 240DL 215K
01 V70 TMU
00 S70 100K
99 V70 189K
94 940 136K
92 240 GL wagon TMU
85 240 DL 196K
90 240 DL 169K
95 850 wagon 250K
99 S70 135K
2006 Volvo XC90 V8
06 XC90 175K sold
02 V70 XC 135K sold
05 XC90 251K sold
92 240DL 215K
01 V70 TMU
00 S70 100K
99 V70 189K
94 940 136K
92 240 GL wagon TMU
85 240 DL 196K
90 240 DL 169K
95 850 wagon 250K
99 S70 135K
AVOIT17
- Year and Model: 2009 XC90 RD
- Has thanked: 6 times
- Been thanked: 16 times
To Know if you need to change your battery - you need to test it with a Battery Tester such as the ANCEL BA101.
https://www.amazon.com/gp/product/B01M0 ... UTF8&psc=1
When Testing - on the XC90 with the battery at the back - you need to do it directly on the battery - therefore at the back and NOT from the relay in the engine compartment.
AVOIT17
...Ho I forgot to mention, SRS Codes I believe needs to be cleared with Vida.... or by going to a Volvo dealer. Reason being related to a major safety issue - air-bags.
aaron1611
I've pulled the 12.2 volts from the battery in the back with the truck off with my tester. The iCarsoft reader claims to clear SRS lights. I have a VIDA but I'm not sure I remember the password to start the program, I'll have to dig for that and repost my findings.AVOIT17 wrote: 19 Jul 2024, 09:38 To Know if you need to change your battery - you need to test it with a Battery Tester such as the ANCEL BA101.
2005 Volvo XC90 V8
2006 Volvo XC90 V8
06 XC90 175K sold
02 V70 XC 135K sold
05 XC90 251K sold
92 240DL 215K
01 V70 TMU
00 S70 100K
99 V70 189K
94 940 136K
92 240 GL wagon TMU
85 240 DL 196K
90 240 DL 169K
95 850 wagon 250K
99 S70 135K
2006 Volvo XC90 V8
06 XC90 175K sold
02 V70 XC 135K sold
05 XC90 251K sold
92 240DL 215K
01 V70 TMU
00 S70 100K
99 V70 189K
94 940 136K
92 240 GL wagon TMU
85 240 DL 196K
90 240 DL 169K
95 850 wagon 250K
99 S70 135K
AVOIT17
12.2 Volt is a little low. Did you test the CCA and the Resistance of the Battery with your tester? And I would fully charge the battery before testing. Charging with a smart-charger would be ideal.
aaron1611
charging the battery now. To be honest, I don't really know how to check resistance....
2005 Volvo XC90 V8
2006 Volvo XC90 V8
06 XC90 175K sold
02 V70 XC 135K sold
05 XC90 251K sold
92 240DL 215K
01 V70 TMU
00 S70 100K
99 V70 189K
94 940 136K
92 240 GL wagon TMU
85 240 DL 196K
90 240 DL 169K
95 850 wagon 250K
99 S70 135K
2006 Volvo XC90 V8
06 XC90 175K sold
02 V70 XC 135K sold
05 XC90 251K sold
92 240DL 215K
01 V70 TMU
00 S70 100K
99 V70 189K
94 940 136K
92 240 GL wagon TMU
85 240 DL 196K
90 240 DL 169K
95 850 wagon 250K
99 S70 135K
- MoVolvos
- Has thanked: 312 times
- Been thanked: 525 times
.aaron1611 wrote: 19 Jul 2024, 08:04 Good morning,
Thank you,
12.2 Volts is considered low, should be at least around 12.6 to 12.8 volts with car off. While it's being Projected the 2012 XC90 is not driven often. Just put it on the charger overnight and removed this morning. It took a full charge meaning the needle (maybe a 40 year old charger) was close to zero. Do an overnight charge and see if anything changes before purchasing a new battery.
aaron1611
battery wouldn't charge above 12.2V so I replaced the battery but it didn't fix anything. I dug deeper into the iCarsoft system and it's telling me Can Signal.Signal Missing.
2005 Volvo XC90 V8
2006 Volvo XC90 V8
06 XC90 175K sold
02 V70 XC 135K sold
05 XC90 251K sold
92 240DL 215K
01 V70 TMU
00 S70 100K
99 V70 189K
94 940 136K
92 240 GL wagon TMU
85 240 DL 196K
90 240 DL 169K
95 850 wagon 250K
99 S70 135K
2006 Volvo XC90 V8
06 XC90 175K sold
02 V70 XC 135K sold
05 XC90 251K sold
92 240DL 215K
01 V70 TMU
00 S70 100K
99 V70 189K
94 940 136K
92 240 GL wagon TMU
85 240 DL 196K
90 240 DL 169K
95 850 wagon 250K
99 S70 135K
- Krons
- Has thanked: 198 times
- Been thanked: 215 times
I’ve cleared SRS faults with an iCarSoft, except for an internal SRS controller fault which requires replacement.aaron1611 wrote: 19 Jul 2024, 10:28I've pulled the 12.2 volts from the battery in the back with the truck off with my tester. The iCarsoft reader claims to clear SRS lights. I have a VIDA but I'm not sure I remember the password to start the program, I'll have to dig for that and repost my findings.AVOIT17 wrote: 19 Jul 2024, 09:38 To Know if you need to change your battery - you need to test it with a Battery Tester such as the ANCEL BA101.
Definitely sort the voltage issue first.
08 C702.5T (sold)
The non-Swedes:
08 C702.5T (sold)
The non-Swedes:
- MoVolvos
.Krons wrote: 19 Jul 2024, 18:24I’ve cleared SRS faults with an iCarSoft, except for an internal SRS controller fault which requires replacement.aaron1611 wrote: 19 Jul 2024, 10:28I've pulled the 12.2 volts from the battery in the back with the truck off with my tester. The iCarsoft reader claims to clear SRS lights. I have a VIDA but I'm not sure I remember the password to start the program, I'll have to dig for that and repost my findings.AVOIT17 wrote: 19 Jul 2024, 09:38 To Know if you need to change your battery - you need to test it with a Battery Tester such as the ANCEL BA101.
I may have missed it but which iCarSoft scanner do you have?
- 1888 Views
- 7663 Views
Last post by drmegadan
- 9160 Views
Last post by spue
- 1546 Views
Last post by SuperHerman
- 9581 Views
Last post by MadeInJapan
