96 850 NA
Wiring to the ABS sensor on passenger side was damaged during suspension/steering work. Now that corner reads low resistance, I think it was like 400 ohms, or anyway I remember it reads under half of what it should read. Fiddling with the connector including cleaning etc, has not helped so I think the wiring itself is damaged. The other three sensors all read within spec, above 1k ohms. ABS and TRACS lights are on since this happened, of course.
How to best fix this problem, any ideas?
In this setup the wiring unplugs at the sensor, you can't order new wiring. Can I run new wires there and if so what should I use? Do I have to break down and use the soldering iron (talk me off the ledge)?
How to fix damaged ABS wiring?
- Has thanked: 312 times
- Been thanked: 818 times
Matty Moo
- Year and Model: 850, 1996
- Has thanked: 1 time
- Been thanked: 30 times
If I had to do it again I would Source another connector at the sensor end and any 20-24 gage wire with a good sheath. Make a new section with a heavy heat shrink at the connector end and fit the other side 8n as far I to the firewall as you can.
You have to solder it on both ends. It is what it is.
http://www.midwest-abs.com
Simplycleanpowerwash.com
1999 s70 Plain Jane.
2000 s70 GLT
2014 Ram
2012 Jeep Wrangler Unlimited
- Has thanked: 1611 times
- Been thanked: 4075 times
Those wires are tough to solder and hold as they need to flex with wheel steering. I must have soldered by rear, with just suspension travel three or four times before I finally broke into the kids college fund and bought a new rear harness (1999, $100 bucks)
Maybe cut one out of a donor and make the solder up high near the ABS module? I think the wire on the -1998 hard connects to the ABS module, unlike the 1999-
- misha
- Has thanked: 155 times
- Been thanked: 432 times
I soldered mine and that wasn't ok.
I ended up buying used wiring and just crimping on bullet terminals(male & female) and heat shrunk them.
Connections are high near firewall.
3 years later and everything ok.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
Anybody have a source for a front ABS connector with some wiring?
Nice “ no tool” junkyard part, except for snippers for the wire.
jmartin919
- Year and Model: S70 GLT SE 2000
- Has thanked: 97 times
- Been thanked: 42 times
Why not take the whole thing?
'00 S70 GLT SE
'82 MB 380SL
'11 MB E350 Sport
'84 Chevy C10
'93 850 GLT NA SOLD
'82 MB 380SL
'11 MB E350 Sport
'84 Chevy C10
'93 850 GLT NA SOLD
That's basically what I'm looking for yes! Cut the wiring as far back to the ABS as possible.
yes
hence I posted as such in the junkyard requests subforum.
main issue is, very few p80's in the yards any more, I found zero in the yards around me
jmartin919
So you're needing the connector that this plugs into plus as much wiring as you can get going back to the module? https://www.volvopartswebstore.com/prod ... 42043.html
'00 S70 GLT SE
'82 MB 380SL
'11 MB E350 Sport
'84 Chevy C10
'93 850 GLT NA SOLD
'82 MB 380SL
'11 MB E350 Sport
'84 Chevy C10
'93 850 GLT NA SOLD
