Bad to worse: Cleaned TB, now erratic idle and stalling Topic is solved
TJWookiee
Year and Model: 2006 XC70 CC
Has thanked: 7 times
Been thanked: 10 times
Post by TJWookiee »
I bought my 2006 XC70 a year ago and it has just crossed the 200K mark. I'd been meaning to try cleaning the throttle body after having mild acceleration issues, and this morning after I stalled while waiting in traffic, I figured the time had come. I'd already picked up a new gasket and a can of cleaner, and I'd been reading a few how-tos posted here and elsewhere for a few days, so I got the car home and went to work very slowly as this was my first time with this particular process.
The TB was pretty dirty but I cleared off all the gunk, slapped on the new gasket and reassembled. I made sure to follow the battery disconnect and reconnect process. After finishing up, I tried starting it up and the idle was up and down, up and down, very rough and much worse than it had been before.
Any ideas on what might be happening? Is it possible cleaning the TB exposed some other issue?
Year and Model: 2001 V70
Has thanked: 987 times
Been thanked: 1075 times
Post by volvolugnut »
Did you get all of the electrical and vacuum connections properly reconnected? Recheck all of them that you may have touched.
Has thanked: 2199 times
Been thanked: 1851 times
If you soaked the TB while cleaning it with spray, you may have damaged the sensors. What did you use to clen the TB with? Hopefully if you leave it overnight it may dry out if this is the issue.
Volvolugnut beat me to the other suggestions!
TJWookiee
Post by TJWookiee »
There were a couple of spots where I sprayed directly, but mostly I sprayed the rag and wiped.
TJWookiee
Post by TJWookiee »
Rookie mistake. I'd mounted the TB 90 degrees from the proper mounting. Took it down, mounted properly, back in business. Let my stupidity help the next guy. Next time, maybe I'll take photos along the way to see how things were instead of relying on my memory.
ignatz
Year and Model: 2006 S60 t5m
Has thanked: 18 times
Been thanked: 33 times
Post by ignatz »
Glad its running better. Did cleaning your throttle body cure your original problem?
2002 V70 2.4
2005 S60 2.5t awd
2006 S60 t5 stick shift
yanga001
Has thanked: 62 times
Been thanked: 115 times
Post by yanga001 »
When i cleaned the MAF i remember having to reset some sort of adaptation as the car would instantly stall. Once cleared, it ran a lot better as it relearned the throttle.
2008 S60 2.5T Auto (Sold)
TJWookiee
Post by TJWookiee »
Yes, ignatz, running better now, idle is steady and acceleration is much improved.
Glad you figured it out! Even better that the car is running better.
