Good evening,
Since blue V70 is on the road again I wanted to get a deeper look into the ECM and its DTCs. Getting a bad start occasionally which throws a DTC.
Used this LED rig described here http://volvo-turbo.de/obd-ii.html but LED stays dark. Always.
Am I doing something wrong?
(Solved) 98 V70 I Fenix - OBD ECM readout with LED not working Topic is solved
MotorTheresa
- Year and Model: V70 1998 B5252F/S MT
- Has thanked: 33 times
- Been thanked: 15 times
- misha
- Has thanked: 155 times
- Been thanked: 432 times
Fuse ok?
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- misha
Possible reversed led polarity?
Did you tried it directly to a car battery?
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
hausmeister
- Year and Model: 1995 850T5-R
- Has thanked: 273 times
- Been thanked: 84 times
Never used that gadget... Are you sure it is wired correctly? - I can't tell from the picture.
You can start by checking if there is the correct voltage for the led present after the resistor and 12v before.. and go from there I think. Test the LED separately etc. probably needs 1-3v. But you probably already got it working I hope.
Also why are you using pin 3?
In any case good luck with the Fenix.
850 T5-R '95 auto
MotorTheresa
Apologies, I just saw your replies here. Will follow the suggestions and check, then come back. Topic still open. Since I get MLC on rough startups it would be just perfect to see what's behind that hardware wise
Will follow up here, sorry for the late response.
- Has thanked: 2197 times
- Been thanked: 1850 times
Have you got the ignition on to position II when testing?
MotorTheresa
Yes, Pos II
MotorTheresa
Today I have turned to this task again and indeed found the LED polarity wrong ... So, good hint!misha wrote: 17 Aug 2024, 13:20 Possible reversed led polarity?
Resoldered and will test tomorrow.
- 3252 Views
Last post by Sommerfeldt
- 3803 Views
Last post by PixelDust
- 5195 Views
- 455 Views
Last post by lukask
- 35 Replies
- 2146 Views
Last post by MotorTheresa
