Hi,
I am converting my 1999 Volvo S70 T5 to full electric. The engine is out. Now stuff is finally going in.
One of the things I have to put in is an electric steering pump. I got one off eBay, a Volvo unit from a 2004-2012 S40/V50/C30.
The manual in my S70 said to use ATF in the original power steering system. The online references I see for the electric power steering pump seem to call for Pentosin.
Detective work: The fluid that's left over in the steering rack seems to be neither. To be honest, it looks like motor oil. I wouldn't put it past the prior owner to have dumped regular oil in there out of laziness, cheapness, or ignorance. I am praying it's not the case though, maybe it's some sort of synthetic ATF. I can't tell what was originally in the PS pump. It's grey, TBH. But I think that, held up under just the right intense light, it may have a green tint: Pentosin.
Here's my dilemma: which fluid should I use? Assuming the rack used ATF, and the pump used Pentosin, which should I use now? Will Pentosin hurt the rack? Will ATF hurt the pump?
Help me, oh my Volvo brethren. I need the best compromise, for reliable function: ATF or Pentosin.
Thanks!
1999 S70 steering rack, 2004-2012 S40 electric steering pump. Which hydraulic fluid to use?
- ThaddeusTheBold
- Year and Model: 1999 S70 T5
- Been thanked: 10 times
- Been thanked: 4064 times
As we say in mathematics , the first problem will be to establish the existence of a compatible fluid between the electric pump and the hydraulic rack
After that is known, uniqueness will hopefully not be a problem.
- ThaddeusTheBold
Well, I'm going to go with the Pentosin. Here's why:
Pentosin is spec'd for some V70's of the same year. V70's appear to use the same PS rack as the S70. So it's possible the rack in my car is fine wih the stuff.
I also thought about failure modes. Pentosin is thinner than ATF. If the pump likes Pentosin, it might damage it to put a heavier fluid in there and expect it to pump. The thinner Pentosin MIGHT sneak past the seals on the ps rack, but again it might not. In the parade of horribles, a leaky PS rack (which may need replacement soon anyway) seems like a less horrific issue than a PS pump that seizes up.
I'll resurrect this thread as needed to let y'all know how it turned out.
- V50M66
- Year and Model: 1998 V70 AWD
- Has thanked: 26 times
- Been thanked: 94 times
Pentosin CHF11S (and later CHF202, which are compatible with each other) is the recommended fluid for all '99 and up Volvos. The fluid is dictated by the pump, not the rack
1998 V70 AWD - Emerald Green/Tan - M56/Delta link swap, VAST tuned, lots of fun
1998 V70 NA - Nautic Blue/Charcoal - Factory M56/slicktop track car
2006 XC70 Ocean Race - workhorse
1999 Saab 9-3 - daily
2004 XC70 - former workhorse, parted
2005 V50 T5 M66 FWD - former garage queen, sold
2002 S40 1.9T - former daily, rear ended
- 2116 Views
Last post by 93Regina
- 30 Replies
- 26974 Views
- 31 Replies
- 7834 Views
- 810 Views
Last post by 007
- 1098 Views
Last post by theWIFES_S70
