Sparkplugs and LPG
perhss70
- Year and Model: s70 1997
- Has thanked: 6 times
- Been thanked: 3 times
I want to replace the plugs on my 1997 2.0T S70 (B5204T3). It has an lpg conversion. Should I go with OEM plugs or are there any alternatives. I got some OEM plugs for an s60. Is the gap different? Thanks in advance
'97 S70 2.0T5
- misha
- Has thanked: 155 times
- Been thanked: 432 times
Check for part #.
Turbo & na use different oe spark plugs.
You can't go wrong with oe Volvo(set of five) spark plugs for turbo engines.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- hiroku
- Year and Model: 2002 V70 T5
- Has thanked: 21 times
- Been thanked: 9 times
That's a PFR6B plug. The 6 in the NGK reference indicates the heat range. The colder plug will be a 7 heat range, which according to the cross-compatibility charts is comparable with Denso 22 or Bosch 5, for example. That is consistent with my experience.
Check the NGK catalogue and look for a compatible plug to the 3500, but with a heat range of 7. I'm not sure they will have one, but it's worth a shot.
I had the same issue finding compatible colder plugs for my LPG-converted T-5. I ended up going with Denso Iridiums (reference IK22), and while the performance was great, their durability was abysmal. LPG is notoriously more demanding of ignition systems, so I chalked that up to normal maintenance and accepted that trade-off. IMO that's better than overheating OEM plugs.
I don't have the LPG car anymore, but my next step would be to try the Denso twin-tip range (IK22TT). It promises much better longevity, so could be worth a shot.
perhss70
Does the spark plug position matter a lot? Ngk 3500 is 3.5mm and Bosch FR5KI332S I found in a local store is 4mmhiroku wrote: 19 Aug 2024, 14:07 That's a PFR6B plug. The 6 in the NGK reference indicates the heat range. The colder plug will be a 7 heat range, which according to the cross-compatibility charts is comparable with Denso 22 or Bosch 5, for example. That is consistent with my experience.
'97 S70 2.0T5
- Goupil
- Year and Model: 98' V70 LPT
- Has thanked: 30 times
- Been thanked: 114 times
Not using LPG, but I run NGK BKR7E on my E85 tuned B5254T per tuner recommandations.
They're 7 heat range, nothing fancy but only around 4€/$ a piece. I gap them at the very lowest of the recommended range (granted I dont run stock boost)
1998 Volvo V70 B5254T M56
1994 Volvo 945 B230FT M90
1985 Volvo 240 B230E
- hiroku
I wouldn't think so, that seems like a compatible plug.perhss70 wrote: 21 Aug 2024, 05:08 Does the spark plug position matter a lot? Ngk 3500 is 3.5mm and Bosch FR5KI332S I found in a local store is 4mm
perhss70
Can I go from iridium plugs to plain nickel?Goupil wrote: 21 Aug 2024, 05:27 Not using LPG, but I run NGK BKR7E on my E85 tuned B5254T per tuner recommandations.
I have heard that it's not recommended but I don't know for these specific engines
'97 S70 2.0T5
- 14 Replies
- 5341 Views
Last post by kaneelschep
- 1119 Views
Last post by JRev
- 14 Replies
- 6399 Views
Last post by Ocelot
- 423 Views
Last post by perhss70
- 1899 Views
Last post by 1bigklutz
