XC70 propshaft play
jagerb
Year and Model: V70XC
Post by jagerb »
Hi everyone!
When i was doing some work in my 2001 XC70 (Viscous coupling) the other day i noticed the propshaft could be turned a bit. (see attached video)
Is this normal, or is something worn?
And yes, there are already 2 bolts from the flange missing because i was taking it off :D
IMG_7513.mov
(18.41 MiB) Downloaded 51 times
Has thanked: 2200 times
Been thanked: 1852 times
I would expect some backlash in the angle gear and the trans.
jagerb
Post by jagerb »
scot850 wrote: 17 Aug 2024, 03:19 I would expect some backlash in the angle gear and the trans.
Thanks you for your response Neil! Is this something that is a big dealbreaker for the AWD system? I took the propshaft out because it was worn, but would like to replace it.
Blacklab467
Year and Model: 2007 xc 70
Has thanked: 117 times
Been thanked: 271 times
Post by Blacklab467 »
That’s perfectly normal. How is your propshaft “worn”? I’d take the CV’s apart on each end and clean and regrease them and get a tiny syringe and get some oil in the centre bearing and it should be good. The way these shafts fail is the rubber support around the bearing sags over time and you wil get a subtle vibration at 40-50 Mph, if it’s not doing that I’d call it good, this is a very expensive part to replace!
You should really take the opportunity to look at the input splines on the angle gear and the collar sleeve at this time. It only takes about an hour to remove the AG with the propshaft off, plus you can then drain and refill the AG at this time (there’s no drain plug). This will also give you a good view of your turbo to see if you need to fix any leaks.
2003 XC 70 (sold)
XC70Rider
Year and Model: 2007 XC70
Has thanked: 36 times
Been thanked: 42 times
Post by XC70Rider »
If your Haldex hasn't been serviced yet then now's the time if you do decide to remove the driveshaft. Replace the haldex filter and remove the oil pump & give a cleaning. Much more oil drains out via the oil pump fitting than when siphoning via the fill plug.
01 does not have a Haldex unit. Not fitted here until 2003/4. It should have the same viscous coupling unit as the P80 AWD's.
jonesg
Year and Model: 2004 V70
Has thanked: 73 times
Been thanked: 532 times
Post by jonesg »
yeh its called ganging, all the slop adds up at the rear of the prop shaft.
Yet another new term learned! Thanks.
jagerb
Post by jagerb »
So, is it normal? (Maybe not from the factory, but normal wear) Or is it excessive, and probably not worth it to replace the propshaft? Sorry, english is not my first language.
And thanks everyone for responding!
For the age I would consider it normal. I was just checking my 2000 V70R which has the same system a few days ago and it has a lot of play in it too. Car runs smoothly when not broken. Actually drives very smoothly when not broken!
