2007 Volvo XC 90 Clunking Front Drivers Side
VolvoS402006
Year and Model: 2006 Volvo S40
Post by VolvoS402006 »
I am hoping someone else may had experience this and can share what they found. I have a 07 XC 90 3.2 FWD auto that is making a clunking sound right under the front drivers side. I have looked under the car and I really can not see anything obvious. The CV looks ok shock isn't loose and the control arm seems tight. I imagine this all could look different when the car is moving. Has anyone experienced something similar? I would really appreciate any similar experiences. :D
Joey
Krons
Year and Model: 08S60 05XC90 02S60
Has thanked: 198 times
Been thanked: 215 times
Post by Krons »
Check the control arms with a pry bar. Visually may look ok but may have a lot of movement. If original they are likely shot.
08 C702.5T (sold)
The non-Swedes:
chitownV
Year and Model: 2008 XC90 3.2
Has thanked: 15 times
Been thanked: 40 times
Post by chitownV »
Is it a rotational clunk, occurs when you start from a stop, or over bumps.
Some things to consider:
  • Lower Control Arm rearward bushing if it happens going over a bump, when turning, or when braking
  • Sway bar end link if going over a bump on either side
  • Rotational could mean the CV
  • If starting from a stop, could also be axle bolt, engine mount
Possibly other things. More description helps, such as when the clunk happens, if it's a fluttering noise, just a clunk, on or off the throttle, etc.
2008 XC90 3.2 AWD - 169k miles, Premium, Versatility 7 passenger, Climate, Convenience, retrofit Morimoto D2S HID bi-xenon, iPd swaybars & poly bushing inserts, Powerflex poly control arm bushings, Bilstein Touring Fr struts, Continental CrossContact LX25 255/55R18, Fr Infinity tweeters & speakers, hardwired cheap $17 Bluetooth to center console aux & pwr, CQuartz UK 3.0 ceramic coated, no oil consumption using Mobil 1 0W-40 even w/ my lead foot
