no start after water pump fitted
hairpuller62
- Year and Model: 2000 v70 2.5d
hi all hope i can find some good advice on this subject, car was running fine until the water pump was fitted, now for some strange reason there is no fuel getting to injectors, any help most welcome.
- Clemens
- Has thanked: 498 times
- Been thanked: 228 times
did you by any chance mess up the timing? Although. this might not cause a no fuel situation
Also, Have you tried bridging the fuel pump relay (#103, I believe)? It might be faulty and nothing to do with the water pump replacement.
next, inspect the fuel pump and try knocking the fuel tank really good with the ignition on. The fuel pump might be on it's way ou after all these years.
1996 855 R,
2010 V70 D5,
2010 V70 D5,
- 16 Replies
- 5892 Views
- 654 Views
Last post by ddmac
- 1868 Views
- 1462 Views
Last post by darrylrobert
- 187 Views
Last post by DragosGD
