1997 850 - Idle Stutters When Warmed Up
Colt99
Year and Model: 1997 850
Post by Colt99 »
So as the subject says, my idle is just fine when it's cold, but as it warms up to operating temperature, it starts stuttering really badly.
The first time this happened, it stuttered for a few minutes, then I gave it some gas and it ended up stalling. After it cooled down for 20-30 minutes, it started back up with no problem. It didn't stutter until it heated up once again.
I've replaced my MAF Sensor, Flame Trap, Fuel Injection Idle Air Control Valve, Fuel Pump Relay, Air Filter, Throttle Control Pulley System, and reconnected the air hose from the grill to the air filter housing, as I saw it was popped off.
I've no clue what it could be, as this is my first car and I want to ask here before spending money unnecessarily.
Thanks!
Has thanked: 2200 times
Been thanked: 1852 times
I would check the fuel pressure at the rail. When was your fuel filter last replaced?
I would also give any vacuum hoses in the engine bay a good check over for splits.
I'd also check the coolant temp sensor connector and the wiring at the connector for corrosion and check it's resistance values.
Finally, check the injector relay on above the radiator for cracked, rusted or broken wires.
Colt99
Post by Colt99 »
Hey there. I finished replacing the fuel filter quite literally this morning, hoping it'd fix it, though unfortunately not.
I ordered a new temp sensor, and a new thermometer, so I'll be replacing both of those sometime this coming week.
I'll check over everything you noted, thanks a lot for your help, I appreciate it.
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2857 times
Been thanked: 1332 times
Post by matthew1 »
Does the dash dim/flicker also? If so, check ground strap, battery cables, battery (age).
Also -> Amazon link
Has thanked: 311 times
Been thanked: 817 times
Post by erikv11 »
Check under the distributor cap for any of these common issues that get worse as the engine warms up:
- a blown rear cam seal leads to accumulated oil and/or moisture
- worn rotor contacts
- worn contacts on the cap
matthew1
Site Admin
Post by matthew1 »
^ Yes, that too.
A good 20% of these air/fuel-presenting symptoms are spark.
Also -> Amazon link
