Sadness - 2002 V70 2.4T - Transmission Service Required - is it time to say goodbye? Topic is solved
Locked
Jonboy74
Year and Model: V70 2.4T, 2002
Has thanked: 119 times
Been thanked: 15 times
Post by Jonboy74 »
Please say it ain’t so. I love this car. I really really love this car.
302,205 miles.
I literally just heard a “thunk” as I was driving down the interstate at 60-65 mph, and that message came up on the dash. No other funny noises or behavior until I dropped down from highway speed. It is obviously now in limp mode.
I had the transmission replaced with a Transtar in January of 2013 for $3,800 at 165,610 miles. (The shop attempted to rebuild my original but was unable to.
I have a feeling my Indy shop will tell me it is toast.
How many have recovered successfully from this warning message in the DIM?
In the meantime, I have to get from my current location to home - about 20 miles. Do I limp home or do I call the tow truck?
Sadly,
Jonboy
Year and Model: 2001 V70
Has thanked: 987 times
Been thanked: 1075 times
Post by volvolugnut »
My 2001 V70 transmission threw multiple Transmission Service Required messages with harsh shifts before I did a series of drains and refills with Mobil 3309 ATF. After 1200 miles all seems OK with smooth shifts and no messages.
Your results may be worse, but don't give up on it yet. But I can't think what might go thunk at highway speeds however.
My car, I would limp home.
MoVolvos
Has thanked: 312 times
Been thanked: 525 times
Post by MoVolvos »
Check the level. color and odor before deciding to limp home but I would tow if it were mine.
Jonboy74
Post by Jonboy74 »
Update: I went ahead and limped home, no issues other than acceleration was slow. Once I was up to around 30 mph, no issues. Did get up to 60 at one point. Didn’t do any crazy acceleration, just gradually increasing to be at safe highway speed. No issues with reverse. I did notice that the gear indicator that normally showed a D looked like a hyphen. I presume that means limp mode.
Jonboy
Jonboy74
Post by Jonboy74 »
volvolugnut wrote: 26 Aug 2024, 19:13 I did a series of drains and refills with Mobil 3309 ATF.
I have seen some threads about this. What was your specific procedure? (Do you have a link to a how to or YouTube video?)
I’m trying to figure out how much time and $$ I am willing to put into it at this point.
Thanks!
Jonboy
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2857 times
Been thanked: 1332 times
Post by matthew1 »
Also -> Amazon link
jonesg
Year and Model: 2004 V70
Has thanked: 73 times
Been thanked: 534 times
Post by jonesg »
Jonboy74 wrote: 27 Aug 2024, 19:26
Thanks!
Jonboy
https://turboautoparts.com/used-transmi ... rbocharged
https://www.erievovo.com/
Has thanked: 1610 times
Been thanked: 4065 times
I have a 2002 parts car with a good trans in Albany NY, too far to tow, but there it is
Free to you.
I also will be heading down to NC in October. RDU area, and can likely drag stuff
Jonboy74
Post by Jonboy74 »
abscate wrote: 29 Aug 2024, 14:24 I have a 2002 parts car with a good trans in Albany NY, too far to tow, but there it is
Free to you.
Hey abscate!
Very kind of you. Ended up doing a drain and fill, still threw a code, but am thinking it may be due to a bad signal from the ECM because it said the engine was going 6k RPM… the ECM has had a hard fault for years, so considering sending it to XeMODeX to be refurbished.
I’m not too terribly far from Raleigh. Would love to meet you in person if the timing works out!
Goodnight Elizabeth! 😂
Jonboy
Jonboy74
Post by Jonboy74 »
Closing this thread out, as I started a more specific thread here:
P2 Multiple RPM signals, one pegs at 6,000 RPM
Locked
