2010 v50 Exhaust odor just at start-up
packetfire
Year and Model: 2010 v50 2.4i
Has thanked: 17 times
Been thanked: 30 times
Post by packetfire »
Weird... start the car, get a whiff of exhaust.
But it goes away in seconds.
Cold car, warmed up engine, car that's been driven for hours, and stopped at a rest stop - all the same.
I know that the climate control system wants to default to "Automatic" on the air re-circulation, but why should there be ANY exhaust smell at the front of the car, even briefly?
Can't be evap or pvc - no codes from the car at all. Has to be the manifold... but how to find the leak? Maybe a non-contact thermometer to look for the hottest area on an otherwise cold engine and exhaust manifold? Any suggestions for the 2.4 liter 5-cylinder?
1982 240DL: Drove it 32 years and 1.5 million miles (sold, even still had mint leather!)
2001 v70 2.4T: The most expensive $1500 car I ever bought ("Volvo Turbo" - what an oxymoron!) (sold)
2004 v70: Far less fatally-flawed v70 - It served well (sold)
2010 v50: Smaller, slightly sportier wagon. Its got a spoiler, so I upgraded with sway bars!
dudeitssm
Year and Model: 2007 V50 2.4i FWD
Has thanked: 2 times
Been thanked: 2 times
Post by dudeitssm »
Hi packet.
This was (and still kind of is) an issue in our other vehicle, a 2005 CRV AWD. There is a moderate exhaust leak at the exhaust manifold.
The way I found it out was by running a shop vac in reverse, so it blew air out, and plugging the hose into the car tailpipe and taping it snug.
Then, I sprayed soap water all over the exhaust section--muffler, pipes from and to the CAT from the manifold. Any leaks will make bubbles.
ChrisFix on YouTube has more details about the procedure.
But mainly, you want to make sure your shop vac filter is clean before you start blowing air thru your exhaust system.
