High Engine Temp!
Wife had me meet her on her ride because there was a dash message "High Engine Temp". After 15 mins of engine off, no message. Antifreeze tank was full...no leaks noticed. Quick Google said "Replace thermostat and/ or sensor". Am I on the right track with those? How do you know if the water pump is operating? Any other ideas?
- Has thanked: 987 times
- Been thanked: 1078 times
Get a reliable high temperature thermometer to check top tank radiator and inlet/outlet of water pump as the engine warms. This will tell you if water pump is pumping and the thermostat is opening.
Confirm the water pump is actually turning.
Use a laser pointer digital non contact thermometer. These are now $30-40? Very handy.
- 1381 Views
Last post by FLXC90
- 1331 Views
Last post by richardgengle
- 711 Views
Last post by fiski
- 4207 Views
Last post by Jose
- 12 Replies
- 3557 Views
Last post by Krons
