Gas Smell. 84 244
AS84244
Year and Model: 1984 244 gl
Has thanked: 1 time
Post by AS84244 »
Hi,
My 244 only has 90k mile and has suddenly started having a gas smell on the inside and outside the car. I haven't seen any gas on the ground around it or anything. Any ideas on what it could be? I have no loss in power and the gauge works fine.
Year and Model: 2001 V70
Has thanked: 987 times
Been thanked: 1075 times
Post by volvolugnut »
Unless a gas leak is huge, the gas will evaporate before it makes a puddle. But you will still smell it. Check the areas you can see (at engine and along the bottom of the floor) for wet spots with the engine running. Likely leaks are at hose sections at the fuel rail and near the fuel pump and filter. The fuel pump and filter are accessible from under the car. The line from the fuel tank to the filter and pump are somewhat accessible from the cover plate in the trunk.
If you replace a hose, be sure you get fuel hose rated for the pressure.
AS84244
Has thanked: 1 time
Post by AS84244 »
Thanks! I'll take a look at those areas.
