I found that the flimsy piece of crap that they call a connector for the TB on this car has broken one of the tabs off. I must have done it while removing it. Can you buy the connector itself, or do you have to buy the whole harness with the pinned connectors at the other end?
The wiring harness part number is : 31409380
I don't want to go to the junkyard to cut one off to fit as it will likely be as plastic hardened flimsy too.
If I go down the harness route for replacement, where does the wire harness other end go to? It looks like they have pins on the wires.
Thanks,
Throttle Body wiring connector source? - 02 XC70
- Has thanked: 2203 times
- packetfire
- Year and Model: 2010 v50 2.4i
- Has thanked: 17 times
- Been thanked: 30 times
Dorman makes a lot of replacement connectors, and might have a match, but take a good photo of the connector, looking into the pins or sockets, and use google image search - you'd be surprised how many Volvo engine harness connectors are used on other cars for things like fuel injector connectors and such, so Ali-Express may have a match.
1982 240DL: Drove it 32 years and 1.5 million miles (sold, even still had mint leather!)
2001 v70 2.4T: The most expensive $1500 car I ever bought ("Volvo Turbo" - what an oxymoron!) (sold)
2004 v70: Far less fatally-flawed v70 - It served well (sold)
2010 v50: Smaller, slightly sportier wagon. Its got a spoiler, so I upgraded with sway bars!
Good idea. I have found both Volvo and PPS wiring harnesses with the connector, but not the actual connector. I will pull one from a junkyard when I get a chance and photograph it. For the time being I have uses some tying wire to hold it firmly in pace and it works for now while I work through the various engine issues to identify if it is worth spending money on.
Thanks for your suggestion.
- 722 Views
Last post by Faust
- 352 Views
Last post by Faust
- 1882 Views
Last post by chrism
- 3413 Views
- 1734 Views
Last post by jake 32137
