Hello all,
I have a '07 XC90. I'm trying to remove the calipers and it has a weird bolt holding them on. It appears it should be a T55, but my T55 is too big and T50 is too small. I took a pic to get a better look at it and it is definitely different. Can anyone tell me what this is and what I need to do to remove it?
Thanks!
07 Caliper Bolt Question
- MoVolvos
- Has thanked: 312 times
- Been thanked: 525 times
.b4sennett wrote: 15 Sep 2024, 09:33 Hello all,
Thanks!
The corrosion might be keeping the T55 from fully fitting properly. Try gently tapping it to see if it will go in fully.
- Been thanked: 504 times
Those Internal Torx bolts hold the 2 halves of the caliper together. Don't touch these bolts when doing the usual brake job...
b4sennett
- Year and Model: 2007 xc90
- Has thanked: 2 times
Thank you...I'm clearly an idiot...I appreciate it!cn90 wrote: 16 Sep 2024, 14:50 Those Internal Torx bolts hold the 2 halves of the caliper together. Don't touch these bolts when doing the usual brake job...
- MoVolvos
- 15 Replies
- 6816 Views
Last post by wizechatmgr
- 661 Views
Last post by E Showell
- 1535 Views
- 3076 Views
Last post by mrbrian200
- 3219 Views
