Noise from Right Rear, 1997 850 base wagon, PLS HELP
dgwdoesthings
Year and Model: 1997 850
Post by dgwdoesthings »
Makes noise for a second when I turn the ignition to start but don't crank, and you can hear it while idling, high pitched whining coming from the right rear.
This noise first started after I recently changed the fuel filter last week.
First thought was that there was a bubble in the fuel system, drove over a hundred miles hoping it would fix itself. Next I assumed it was a sign of a fuel pump, I just swapped it for a new one today. Noise is slightly different but persists, used to be lower rattly whining if that makes sense.
Will post a sound/video when I figure out how to, new to forum
Any clues as to the problem?
Thanks for the help
misha
Has thanked: 155 times
Been thanked: 432 times
Post by misha »
It's the fuel pump.
Check the fuel filter direction...arrow must point towards the engine.
What is the brand of fuel pump?
Some of them are a lot louder than original.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
