Do replacement seatbelt tensioners need programming? 07 V50 2.4i FWD
dudeitssm
Year and Model: 2007 V50 2.4i FWD
Has thanked: 2 times
Been thanked: 2 times
Post by dudeitssm »
Continuing the deer hit-and-run saga from here, now that the car is up and running (yay!):
viewtopic.php?t=105273
All 4 of my seatbelts and tensioners need replacing.
Question is: should I buy used off eBay, or should I get my current locked-up ones rebuilt by sellers on eBay?
Does anyone know for a fact if replacement seatbelt tensioners, which have yellow terminals (I assume SRS module activated), require programming to be used properly in another car?
Mine is a 2007 Volvo V50 2.4i FWD.
Thank you.
dudeitssm
Post by dudeitssm »
UPDATE: according to one seller I reached out to on eBay, he stated that typically they do need programming... Again, he's not sure.
Is there someone here who can confirm if indeed seatbelt tensioners need programming on this model?
Alternative, if programming is possible via VIDA DICE, does anyone have a guide?
Thanks again.
dudeitssm
Post by dudeitssm »
Bump!
dudeitssm
Post by dudeitssm »
Another bump!
