Hey all,
Was wondering if anyone could offer any suggestions or insight as to what I'm seeing here...
Back on the 5th of this month, my wife was driving and all the electronics went "wonky" on her. Lost power steering...trans acting weird. She managed to park it and while waiting for a tow, the car completely went dead.
Anyway, once we got the car home, I took a reading off the DieHard battery and read about 8.4 VDC. I replaced it with a new Everstart Platinum AGM and everything seemed fine for a couple weeks until 2-3 days ago.
Now I'm getting an intermittent "Charging Failure-Service Urgent" message periodically that will go away after a few minutes, but then come back on the next day or so.
With the vehicle off, the battery is still reading a good 12.45 VDC and roughly the same when running as well.
I tried disconnecting the BMS for 30 seconds while running, and when I tried the Ignition Mode II/Parking Lights/Rear Fog 6x/Hazard 3x I never saw the battery indicator flash on the dash...
Any info would be appreciated. TIA
Charging Failure on 2011 XC70 T6
pinegrovedave
- Year and Model: 2011 XC70 T6
- Has thanked: 3 times
- Krons
- Has thanked: 198 times
- Been thanked: 215 times
Alternator or regulator could be going bad.
08 C702.5T (sold)
The non-Swedes:
08 C702.5T (sold)
The non-Swedes:
- pgill
- Year and Model: 2010 S80, 2008 LR2
- Has thanked: 120 times
- Been thanked: 189 times
Dave,
There are different failure modes. We need more information.
1. Is the Alternator spinning?
If not then read this https://www.aulro.com/afvb/freelander-2 ... owner.html
2. Is the small control wire broken?
read this to find out more https://www.freel2.com/forum/topic32004 ... tery+light
3. If it isn't #1 or #2 then you may need to rebuild or get a rebuilt Alternator
Take a look here https://www.freel2.com/forum/topic39641.html
Let us know how many miles are on your vehicle and if the overdrive pulley for the alternator has been replaced
Good luck
Paul
Good luck
Paul
pinegrovedave
Hi Paul,
Weird...I didn't get notification that you replied...Anyway, yeah the alternator was spinning and the voltage was bouncing between 11 and 14.5 VDC so I went ahead and bought an AC Delco remanufactured alternator. Put it in today...and as luck would have it, the control wire connector clip snapped off. I'm not getting any voltage and I suspect the harness isn't making the connection at the alternator. Ugh.
- 2020 Views
Last post by giegaand1
- 12 Replies
- 11505 Views
Last post by warcraftjunkie
- 13 Replies
- 12543 Views
Last post by Yak
- 3337 Views
Last post by GoLuckydog
- 4599 Views
Last post by oragex
