94 Volvo 850 ABS light on no codes in A3 code is 1-1-1 same in A2 A1.
Any ideas?
Recently replaced starter had fan shroud off with all relays disconnect then reconnect could this be an area to look at?
Thanks.
94 volvo 850 ABS light on no codes in A3
- Has thanked: 2210 times
Check the wiring connections. The pins on the wires and the wiring connections themselves get brittle with age and can become intermittent while looking ok.
- xanthefin
- Year and Model: 1997 850
- Has thanked: 106 times
- Been thanked: 130 times
There was one who had ABS module failing so that connection to dashboard ABS light were beaking so there was no ABS codes as it doesnt monitor light bulb in dashboard. Next can break other connections.
ABS module does not light up the light it only shuts the light so function is reversed so that connection if is broken you can result light on and no codes.
cpl
- Year and Model: 1994 850T 2004 S60
- Has thanked: 2 times
- Been thanked: 2 times
Only connection loose was the one that went to the coolant relay the one in the middle yellow & yellow-white wire
Found online the ANTI-LOCK BRAKE SYSTEM & TRACTION CONTROL 1995 Volvo 850
https://www.volvoclub.org.uk/tech/servi ... ontrol.pdf
Even thought it's for a 95 not a 94 on page 15
ABS WARNING INDICATOR LIGHTS, NO DTC DISPLAYED
directions was to drive it over 25 mph to see if the light goes out, it did, unbelievable!
1994 855T Teal
2004 S60
2006 XC70
1990 F150 XLT Old Blue; I sure do miss Old Blue
2004 S60
2006 XC70
