part removal query
ptV70
Year and Model: 2005 V70
Post by ptV70 »
I replaced the passenger side front door lock assembly on a 2005 V70 yesterday. On reassembly found the triangular plastic cover over the side view mirror bolts (interior cover) has 2 of 3 pins broken off, and the door itself is missing one of the three metal tubes that the cover pins snap into. I want to replace the missing tube, and get a cover, from my local salvage yard. My question: How to remove those metal tubes and reuse. Thank you.
jonesg
Year and Model: 2004 V70
Has thanked: 73 times
Been thanked: 534 times
Post by jonesg »
ptV70 wrote: 22 Sep 2024, 09:40 I replaced the passenger side front door lock assembly on a 2005 V70 yesterday. On reassembly found the triangular plastic cover over the side view mirror bolts (interior cover) has 2 of 3 pins broken off, and the door itself is missing one of the three metal tubes that the cover pins snap into. I want to replace the missing tube, and get a cover, from my local salvage yard. My question: How to remove those metal tubes and reuse. Thank you.
remove the side mirror, on mine the pins are black plastic.
I glued the trim in place with goop.
ptV70
Post by ptV70 »
Thank you jonesg. I did not make myself clear -- I seek to replace the metal tubes into which the triangular interior trim piece snaps; I do not want to do anything with the side mirror. Are you saying the mirror has to be removed to remove the metal tubes?
Year and Model: 2004 V70 2.5T
Been thanked: 504 times
Post by cn90 »
Iirc, the tiny metal tubes have prongs on the other side.
It is a press-fit kind of thing.
Just get a pair of pliers and pull it out.
Once you go to junk yard, then it will be obvious.
Post by cn90 »
PN is included: 9151566, about $4-$5 at dealer.
ptV70
Post by ptV70 »
Thank you! This is just what I needed!
