04 S60 - Windshield Washer Pump Always on with wipers Topic is solved
br0dy519
Year and Model: 2004 XC70
Has thanked: 132 times
Been thanked: 126 times
Post by br0dy519 »
As per title. Found a fun new gremlin on the S60 today. Intermittent right now but bound to get worse.
Every time my wipers are engaged, the pump is running. Doesn't matter what speed setting. I've read it can actually be a bad headlight washer motor causing this. Any truth?
Need to look at the wiring diagram to begin troubleshooting, just shooting it out there to see if anyone else had this. My guess is a bad stalk possibly just need to isolate and begin troubleshooting.
04s60 2.4
04xc70 2.5t
Year and Model: 2004 V70 2.5T
Been thanked: 504 times
Post by cn90 »
Probably a stalk issue.
Get a good used stalk from junk yard.
It is a 10-min swap and see what happens.
br0dy519
Post by br0dy519 »
Solved!
Mine and @cn90 's hunches were correct. Stalk was the issue. Followed this video and cleaned contacts on the stalk's control board. Appears grease inside with the little slider can gum up the control board contacts. Easy peasy 15 minute and FREE repair. Did the turn signal stalk as well since I had everything apart. Just used 99% Iso alcohol and a white eraser.
04s60 2.4
04xc70 2.5t
ljsommar1
Year and Model: 2002V70
Been thanked: 8 times
Post by ljsommar1 »
I purchased a used unit from Erie scrapyard and installed this afternoon, 15 minute job and it resolved the issue.
Thanks to everyone for the help. It will be nice to have wiper delay for sure.
