I can change gears without the key being in the ignition, 2007 XC70
AylmerQc
Year and Model: 2007 XC70
Has thanked: 62 times
Post by AylmerQc »
Is there something broken or that needs adjusting to remedy this?
Blacklab467
Year and Model: 2007 xc 70
Has thanked: 117 times
Been thanked: 271 times
Post by Blacklab467 »
Check the shifter lock cable on the left side of the console, you'll need to take the drivers side trim off the console side. there's a yellow connector block on the end of the cable that attaches it to the shifter that may be broken. Excluding that, the column lock may have something broken where this cable goes into it. Normally the key has to go to position 2 in the column lock to move the shifter. You'll have to remove the steering column to access the cable and column lock which is just a few torx T-25's and a flathead screwdriver to see where it attaches on the shifter. It should be pretty easy to find the problem with this trim off.
2003 XC 70 (sold)
br0dy519
Year and Model: 2004 XC70
Has thanked: 132 times
Been thanked: 126 times
Post by br0dy519 »
Might be the shifter knob button as well. It can break and get jammed causing the rod to always be engaged. I would remove the shifter knob and look inside and check the movement. It's very easy to do just don't accidentally punch yourself square in the mouth like I did when I was removing mine.
04s60 2.4
04xc70 2.5t
MoVolvos
Has thanked: 312 times
Been thanked: 525 times
Post by MoVolvos »
AylmerQc wrote: 25 Sep 2024, 07:32 Is there something broken or that needs adjusting to remedy this?
I'm almost positive the second video in the link will provide enough info on tearing into it and finding the problem. For me the shifter broke and was having a very difficult time going into and out of gears.
(EDIT: Should Be The Same Assembly According To Volvo Website IIRC)
Console Removal
viewtopic.php?p=644911&hilit=2012+XC90#p644911
Yellow Connector Block per Blacklab467
viewtopic.php?p=644386&hilit=2012+XC90#p644386
Don't Try This At Home :lol:, still working smoothly however
viewtopic.php?p=646002&hilit=2012+XC90#p646002
Year and Model: 2001 V70
Has thanked: 987 times
Been thanked: 1075 times
Post by volvolugnut »
br0dy519 wrote: 25 Sep 2024, 10:56 Might be the shifter knob button as well. It can break and get jammed causing the rod to always be engaged. I would remove the shifter knob and look inside and check the movement. It's very easy to do just don't accidentally punch yourself square in the mouth like I did when I was removing mine.
On my 2001 V70, the shifter button is permanently depressed by a botched button replacement. It allows shifting through all gears without pushing the shift lock button.
It does not allow shifting in OFF or Position 1.
MoVolvos
Post by MoVolvos »
volvolugnut wrote: 25 Sep 2024, 15:22
Wow, another scenario and that one seems dangerous as it can be bumped into reverse by accident!
MoVolvos wrote: 25 Sep 2024, 15:33
Yup, dangerous like most of my old,odd fleet.
br0dy519
Post by br0dy519 »
Lugnut, if you have the metal rod version, it's possible it's too long and needs shaved down a bit. It's likely hanging up on the plastic, you can open it and look for scouring. Or just live on the edge.
04s60 2.4
04xc70 2.5t
I have the other version.
I am happy on the edge.
volvolugnutr
MoVolvos
Post by MoVolvos »
volvolugnut wrote: 25 Sep 2024, 19:27
:D
