Hi
Currently I have Volvo XC60 2014 D4 with and P2000 fault which is "NOX Trap Efficiency Below Threshold". as the car is High in Milage, would I be correct the NOX sensor is possible the fault? and may require replacement?
If this is the case where is its location "pre or post DPF"?
also Is there a requirement for calibration procedure for new NOX sensor?
or is it worth an attempt to clean the sensor?
P2000 Error NOX sensor
- 1249 Views
- 34 Replies
- 2109 Views
Last post by gmh
- 1695 Views
Last post by Bigbill55
- 21239 Views
Last post by MadeInJapan
- 2131 Views
Last post by WhatAmIDoing
