Door speakers Volvo 850 1992
JoachimStorbukt
- Year and Model: 1992 850 GLT
Hello! I am having problems finding the wires for the door speakers that connect to the head unit. My 850 did not come with door speakers from the factory but the wires are there for me to connect a speaker, the problem I am having is that the wires are not getting any power. So I figured that there must be a connector that has not been plugged in. I have been trying to locate the wires with no luck, and I really don’t want to remove the dashboard to find it
does someone know where it might be located?
- Has thanked: 2856 times
- Been thanked: 1332 times
Welcome to MVS!
Look at the wire colors coming off the back of the radio wire harness. Do those wire colors go to the doors? That's where I'd start.
JoachimStorbukt
Thank you
The wires in the left door are Green white and green brown, the right door is red white and res black. The connector in the HU has a male connector attached with purple, green, grey and white wires, but this connector has no female connector attached. So i believe this needs to be connected to a female for the door speakers to work. There seems to be no wires from the door that connects to that HU
- Has thanked: 2199 times
There are normally 2 rectangular connectors on the back of the Volvo radio unit. I'll assume you don't have the amplifier option (if it has one it is hidden behind the radio.
The 2 rectangular connectors hold the speaker and power wires to/from the radio as well as the lighting wire for the front of the radio and if a sedan, the power connection for the rear antenna.
You should also have a single round pin for the antenna the plugs in near the bottom of the rear of the radio.
- 901 Views
Last post by mydamnvolvo
- 3016 Views
Last post by clarkerussell
- 608 Views
Last post by capnjim
- 588 Views
Last post by Rob1
- 1149 Views
Last post by rspi
