SWM audio controls not working?
dikidera
Year and Model: S60 2005
Has thanked: 68 times
Been thanked: 187 times
Post by dikidera »
On my S60 2005 I have had an issue with the audio controls on the steering wheel. The volume up and down buttons dont seem to work and also station change. I replaced my HU650 because of the dreaded FM issue, the controls seems to have worked in the beginning now they are on the fritz. After shutting off the car for a bit(10 minutes) I inserted the key and tested the controls again, for some reason holding the Volume up/down buttons caused the radio to enter some "search" mode but still failed to control volume?
Is this a SWM issue, or is the replacement HU650 starting to bug out? The Cruise buttons work flawlessly.
Another thing for the laughs, if I press on the volume up or down buttons very very hard, the car honks.
mildredcollett
Year and Model: volvo 2020 xc90
Post by mildredcollett »
dikidera wrote: 04 Oct 2024, 09:47 On my S60 2005 I have had an issue with the audio controls on the steering wheel. The volume up and down buttons dont seem to work and also station change. I replaced my HU650 because of the dreaded FM issue, the controls seems to have worked in the beginning now they are on the fritz. After shutting off the car for a bit(10 minutes) I inserted the key and tested the controls again, for some reason holding the Volume up/down buttons caused the radio to enter some "search" mode but still failed to control volume?
I think this is a SWM issue. Ensure that the connections to the SWM are secure. A loose or corroded connection can lead to intermittent issues.
dikidera
Post by dikidera »
mildredcollett wrote: 21 Oct 2024, 12:09
Thank you. When driving over potholes I do feel something loose behind the airbag, I keep thinking something may be loose or broken there. The controls are again working just fine, I guess until they aren't.
darylrobert
Year and Model: V70 240 740t xc70
Has thanked: 6 times
Been thanked: 44 times
Post by darylrobert »
[/quote]
how does that happen>?
Has thanked: 1610 times
Been thanked: 4068 times
darylrobert wrote: 13 Sep 2025, 03:03 Another thing for the laughs, if I press on the volume up or down buttons very very hard, the car honks.
[/quote]
If you push too hard you activate the horn button!
