Likely hood of bent valves with broken timing belt
95Kevin
Year and Model: 95 850
Post by 95Kevin »
This is my Daughter's `95 850GLT (AKA Kevin). The timing belt broke as she was backing into a parking space on campus. Before we start to order a new timing belt kit for it, what is the likely hood of the valves being damaged, and yes she did tried to restart the car before checking to see if the belt broke.
Thanks, Mom
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2866 times
Been thanked: 1332 times
Post by matthew1 »
Unfortunately it's high. Ask her if she heard an awful mechanical sound from the engine.
Also -> Amazon link
MoVolvos
Has thanked: 312 times
Been thanked: 525 times
Post by MoVolvos »
95Kevin wrote: 09 Oct 2024, 11:18 This is my Daughter's `95 850GLT (AKA Kevin). The timing belt broke as she was backing into a parking space on campus. Before we start to order a new timing belt kit for it, what is the likely hood of the valves being damaged, and yes she did tried to restart the car before checking to see if the belt broke.
Thanks, Mom
Pull the spark plugs and purchase any generic Endoscope Camera to check for valve to piston marks.
Endoscope Camera
https://www.amazon.com/Anykit-Endoscope ... 107&sr=8-8
foggydogg
Has thanked: 83 times
Been thanked: 405 times
Post by foggydogg »
These motors are called interference engines because of the lack of clearance between the valves and pistons if the timing belt is off even a few teeth on the sprocket. There will be multiple valves bent, and the repair is quite time consuming; depending on the model the valves themselves are expensive. We all like these cars, so this is a sad story to hear.
Best wishes.
Clemens
Has thanked: 501 times
Been thanked: 228 times
Post by Clemens »
I bought a 93 Civic VTec with a broken timing belt (it broke while it eas idling) anf after slapping a new belt on it drove just fine. vtecs are intereference, as well, btw.
you and your daughter might be lucky, but as others said, it's not very likely. I'd give it a go after using an endoscope camera
1996 855 R,
2010 V70 D5,
Has thanked: 1613 times
Been thanked: 4078 times
There’s a great Volvo garage in Burlington if that’s nearby. A compression test will tell the tale of the top end, definitively
foggydogg
Post by foggydogg »
Thanks, Mom
The only way that this event would not have resulted in the valves contacting the piston tops would be the (very) unlikely alignment of the cam sprockets on their respective timing marks when the timing belt broke. That is the only scenario that would allow the crankshaft to rotate without touching the valves. Spinning the engine with the starter motor produces enough force to cause damage if the cams are not on their marks.
Some posters here have had a touch of luck putting new belts on engines that have suffered a timing component failure - I am among that
group - but that is only after recognizing the problem as it happened, and the belt remaining intact with no more than a tooth or 2 out of time.
As Dr. Abscate suggested, finding a local independent garage familiar with Volvo's to look at the car might be best to weigh your options.
Removing and replacing the cylinder head is very labor intensive.
5underpressure
Year and Model: 1998 v70
Has thanked: 11 times
Been thanked: 13 times
Post by 5underpressure »
abscate wrote: 11 Oct 2024, 03:23 There’s a great Volvo garage in Burlington if that’s nearby. A compression test will tell the tale of the top end, definitively
If he’s closer to the southern end of the state, I could even lend a hand with Compression testing and endoscope looking.
5underpressure wrote: 14 Oct 2024, 10:49
That’s real nice of you, 5UP!
BEJinFbk
Year and Model: '98 V70 R
Has thanked: 94 times
Been thanked: 146 times
Post by BEJinFbk »
Is Clearwater still a good source for rebuilding these heads?
