When did they quit making them?
It’s based on the S40 chassis?
Would you say it’s essentially the 850 white block drivetrain?
Reliable?
Thanks -
What was the last year for the C30 coupe?
- Has thanked: 2199 times
- Been thanked: 1851 times
Last year was 2013 in NA:
https://en.wikipedia.org/wiki/Volvo_C30
Block is the same, but everything around it different. Turbo is in different location, as is alternator. Intercooler pipes are also different. Air box is a pain to remove. You have to remove the 2 engine mount bolts on the RHS and then use a long bar to force the engine back to hope to make enough clearance to remove it without breaking plastics. Thermostat is tucked under the airbox.
Just a lot less room to play with under the hood. It is not terrible but you will have challenges.
Check for broken or blocked sunroof drains.
Fun little car, just wish I fit!
Good luck in your hunt!
- 27 Replies
- 885 Views
Last post by BlackBart
- 2778 Views
Last post by TheMrFailz
- 2049 Views
Last post by oragex
- 1049 Views
Last post by 850forum
- 7592 Views
