1996 Volvo 850 GLT Wagon with Manual transmission.
I have a problem with the drive cycles. None of the sensors want to go into the ready position after installing new Bosch O2 sensors and 3 complete multi-step cycles. (This is quite confusing, because prior to replacing the O2 sensors most of the other sensors went into the ready position.)
Does anybody have any ideas?
Thank You,
(pic of OBD-II display)
OBD-II Drive Cycle Problem Topic is solved
- jreed
- Has thanked: 384 times
- Been thanked: 221 times
Just checking that you had the AC off and did not exceed 60mph per the advice below:
viewtopic.php?t=14429&start=10
bluewagon
- Year and Model: 1996 850 Wagon
- Has thanked: 2 times
Thank you for your reply.
a/c was off, and I did not exceed 60 mph during the drive.
I did notice something else. Using the bluetooth connection on the OBD-II reader unit I discovered a stored code PO422 (bad catalytic converter). Oddly, I do not have a check engine light along with that code. (Yes, the check engine light comes on when the key is in the start position before the car starts so it is not burned out.) Could this stored code be related to the sensors not going into a ready status?
- jreed
That's puzzling that the P0422 is stored. Did you reset the codes after replacing the oxygen sensors?
bluewagon
Thank you,jreed wrote: 21 Oct 2024, 05:36 That's puzzling that the P0422 is stored. Did you reset the codes after replacing the oxygen sensors?
This Odd-yssey began with the failure of the Secondary Air Pump. That threw the CEL. After it was replaced the mechanic reset the SEL. I could not get all of the sensors to reset so I replaced the fore and aft non-Bosch O2 sensors with new Bosch units. After I replaced the O2 sensors I cleared the codes.
My OBD-II reader has a bluetooth connection feature. I just set it up and found the stored P0422 code.
bluewagon
Thank You,xanthefin wrote: 21 Oct 2024, 06:59 I want just shortly share. Not all codes trigger MIL/Check Engine light. And Yes most likely fault code is related.
Picture got lost in bit space.
- 38 Replies
- 8063 Views
Last post by wizechatmgr
- 17 Replies
- 4071 Views
Last post by swedehast
- 828 Views
Last post by matthew1
- 67 Replies
- 5157 Views
Last post by MrAl
- 40 Replies
- 2793 Views
Last post by MrAl
