Only when the car is moving and I'm accelerating, do I hear a rapid ticking sound and thought it may have been a leaf in the vent (that's kind of what it sounds like) but when I put my head close to it it seems it coming from behind the speedometer. Any ideas? -- thanks
I've tried banging on the dash lightly but nothing seems to make it go away and it always sounds the same.
1998 S70 -- ticking sound behind dashboard
- Has thanked: 2197 times
- Been thanked: 1850 times
That is strange. It would suggest from the fact it only happens when you are moving it is coming from somewhere other than the cabin as it is hard to understand what is inside that only ticks when moving. The only thing I can think if is maybe the speedometer or possibly the famous gear teeth on the odometer failing?
- BEJinFbk
- Year and Model: '98 V70 R
- Has thanked: 94 times
- Been thanked: 146 times
Maybe for an 850, but the 98's arescot850 wrote: 22 Oct 2024, 16:52 That is strange. It would suggest from the fact it only happens when you are moving it is coming from somewhere other than the cabin as it is hard to understand what is inside that only ticks when moving. The only thing I can think if is maybe the speedometer or possibly the famous gear teeth on the odometer failing?
all electronic as far as speedo/odo.
The only thing that I can think of that
moves back there would be an ECC
damper motor...
OP - Can you post some audio of your noise?
But why would it only tick when the car is moving. If it was an ECC fault it would tick all the time?
- 1664 Views
Last post by polskamafia mjl
- 2063 Views
Last post by oragex
- 1701 Views
Last post by RickHaleParker
- 14 Replies
- 1049 Views
Last post by hotdog067
- 9086 Views
Last post by sleddriver
