I have a 95 850 wagon, looks as if the catalic converter has been replaced, I have done the plugs and wires and cap and rotor. Car has 145k on it and a new timing belt recently. I have a feeling it might be the catalic converter Not sure if the correct one was put in prior to me buying the car. how can I check it and where can I get a new one.
Thanks
low power up hill
- Has thanked: 2864 times
- Been thanked: 1332 times
No codes/CE light on?
The odds of a clogged/restricted/bad cat convertor throwing a code are much better than even... so let's back up...
Low power going up hills you mentioned. Low power accelerating? Anything else? Smoke? Stalling? Awful exhaust smells?
- Danonly55
- Year and Model: 1996 850 sedan
- Has thanked: 23 times
- Been thanked: 4 times
It has low power accelerating, no smoke not stalling, kind of an odd smelling exhaust.
2014 Ford 3.5L ecoboost XLT
1995 Volvo 850 wagon GLE
Life is tough, but it's tougher when your stupid'
" John Wayne
" John Wayne
How much down on power would you estimate it is? If you're sure it's the cat causing the loss of power I'd look for a cat... well, this can get touchy with the state laws we all have now... but if you can, buy a used one, unless you have money, a jet, four mansions, a yacht or two and a helicopter. That's how much I'd guess you'd need for a new cat from the dealer, if they even still sell them.
Air filter ok?
Air filter ok?
- Danonly55
Creative and funny answer, Air filter is clean.
Thanks. When I get it figured out I will post results.
" John Wayne
" John Wayne
- Clemens
- Has thanked: 500 times
- Been thanked: 228 times
wasn't there an easy method to measure the exhaust temp before and after the cat with an IR Thermometer? if the difference is too high, the cat is blocked.
1996 855 R,
2010 V70 D5,
2010 V70 D5,
Excellent suggestion. Or use the poor man's IR thermometer: run it around good then look under there to see if it's glowing.
- Has thanked: 987 times
- Been thanked: 1078 times
Accuracy is improved at night.matthew1 wrote: 28 Oct 2024, 14:50 Excellent suggestion. Or use the poor man's IR thermometer: run it around good then look under there to see if it's glowing.
volvolugnutr
- 2361 Views
Last post by Livens
- 2733 Views
Last post by Eastsidegeorgiaboy
- 1023 Views
Last post by savkaklopot
- 893 Views
Last post by rspi
- 1788 Views
Last post by Mikele82
