Replacing turbo vac line 98 t5
coop
- Year and Model: 1998 s70 t5
- Has thanked: 17 times
- Been thanked: 15 times
Is there a trick or simplistic way to accessing the turbo to replace the line that goes from the turbo to the turbo control module? You can’t see where it attaches from the top of the engine. Not sure if you can get to it from under the block or you gotta take off the intercooler pipe etc.
- Sveedy
- Has thanked: 445 times
- Been thanked: 479 times
You're going to have to remove the pipe to get good access to the CBV hose on the turbo. You want all of those turbo hoses good and tight anyway, so while you're driving along having a good time, when you hit boost, something doesn't pop off.
1999 V70 GLT
1999 V70 GLT
