Car goes into limp mode with ABS fuse #1 in. 2007 XC70
AylmerQc
Year and Model: 2007 XC70
Has thanked: 62 times
Post by AylmerQc »
If I take fuse #1 out (fuse box in engine compartment) it runs normal but has an ABS fault.
Quickest or first step in troubleshooting?
Just a note to say I do have a Dice unit and VDASH but I'm still not sure of what I'm supposed to be seeing to pinpoint a cause, if that's possible...
jonesg
Year and Model: 2004 V70
Has thanked: 73 times
Been thanked: 534 times
Post by jonesg »
it can be as simple as a loose abs sensor, did you read the codes.?
AylmerQc
Post by AylmerQc »
The codes in VDASH?
Does the car itself show codes on the display besides the visual warnings?
Has thanked: 311 times
Been thanked: 817 times
Post by erikv11 »
Yes, VIDA will show you codes that are far more detailed than any message on the dash. Reading the codes is the first step in troubleshooting.
