06 xc90 with 2.5
CraigT
Year and Model: 2004 V70R
Post by CraigT »
Recently purchased the above vehicle with known coolant burning issue.
120 to 130 psi on cylinders
#1 plug cleaner then the test
#1 piston top cleaner as well.
no oil coolant
no coolant in oil
No noise from turbo
Vida doesn't show any misfires
When purchased, I was thinking HG or worse case cracked cylinder liner. Not so sure of that now.
Found engine from an 07 for $600 from local yard.
Not sure of a direction to go right now. Does anyone have any?
Thank you
Craig
Krons
Year and Model: 08S60 05XC90 02S60
Has thanked: 198 times
Been thanked: 215 times
Post by Krons »
How much coolant you losing?
Certain there is no external leaks?
08 C702.5T (sold)
The non-Swedes:
Year and Model: 2004 V70 2.5T
Been thanked: 504 times
Post by cn90 »
Test for combustion byproducts in coolant before swapping engine.
Many 2.5T engines consumes a bit of coolant here and there. Mine drinks 1/2 cup every 5K.
CraigT
Post by CraigT »
Drinks coolant like a drunken sailor. And starts immediately upon startup, which is quick.
