C70 Subframe Bolts on 850 w/o Horseshoe Brace Topic is solved
jtang56
Year and Model: 1996 850R
Has thanked: 1 time
Post by jtang56 »
Hi all,
Long time lurker here but have never posted. I'm looking to replace the subframe in my 850R with a C70 convertible subframe, though I don't have the horseshoe brace. I just want to confirm that since I'm not installing the brace, I can use the same size bolts as my 850 originally had (100mm? https://www.ipdusa.com/products/8858/12 ... shing-bolt)
My understanding is that the brace is the part that requires the extra 20mm of the bolt, but the subframe itself can mount directly onto the 850 with no additional hardware.
V50M66
Year and Model: 1998 V70 AWD
Has thanked: 26 times
Been thanked: 94 times
Post by V50M66 »
Correct. Same hardware unless adding the brace, then the rear two get the longer bolts. I'd highly suggest adding that brace while you're at it though - it stiffens up the car nicely
1998 V70 AWD - Emerald Green/Tan - M56/Delta link swap, VAST tuned, lots of fun
1998 V70 NA - Nautic Blue/Charcoal - Factory M56/slicktop track car
2006 XC70 Ocean Race - workhorse
1999 Saab 9-3 - daily
2004 XC70 - former workhorse, parted
2005 V50 T5 M66 FWD - former garage queen, sold
2002 S40 1.9T - former daily, rear ended
Has thanked: 2199 times
Been thanked: 1852 times
It would be a challenge to ship, but if anyone needs the C70 sub-frame brace pair I have a set. I got them for the R before discovering you can't fit them to an AWD P80 due to the prop-shaft center support bearing using the mounting holes the main brace uses.
