Rear cam sensor replacement '05 v70 n/a
Faust
- Year and Model: xc70 2008
- Has thanked: 31 times
- Been thanked: 10 times
I am getting codes (PO365 and another) that my rear (exhaust?) cam sensor is faulty. The only video I can find indicates removal of the top motor mount, the crossbar and an aluminum top housing before removing the cover of the sensor. Now that I have got it out, it appears the sensor could be removed without all that work. This by removing the one screw holding the sensor. Has anyone done this? Is it necessary to replace the plastic housing the sensor rests in? If that is necessary, it is another ball game.
2004 V70
1964 Plymouth Convert (small block)
1967 Dodge Coronet (big block)
Faust
I may have spoken too soon. I found a video which suggests that the rear sensor can be removed by removing one 10mm bolt. I do wish they had shown the operation as the bolt position is difficult. But replacement of the sensor is about the same as the front sensor, just more difficult to reach.
2004 V70
- jonesg
- Year and Model: 2004 V70
- Has thanked: 73 times
- Been thanked: 534 times
getting access is the real work, removal is nothing. Its just a small torx bolt on mine.Faust wrote: 19 Nov 2024, 15:17 I may have spoken too soon. I found a video which suggests that the rear sensor can be removed by removing one 10mm bolt. I do wish they had shown the operation as the bolt position is difficult. But replacement of the sensor is about the same as the front sensor, just more difficult to reach.
I think you do have to remove the motor mount to get to the exhaust sensor on RN engines, 99-
- 23 Replies
- 2574 Views
- 2055 Views
Last post by wizechatmgr
- 1496 Views
Last post by iRenaissanceMan
- 733 Views
Last post by Mikestaz5
- 887 Views
Last post by carboncow
