Hello,
I attempted to search for high mount brake light (HMBL) posts but was unable to find what I was looking for.
My HMBL is intermittently coming on and off. I recently replaced my brake switch and my standard brake lights are working fine. It's only the HMBL that's faulty. IPD is selling the assembly for $60 but I'd hate to drop that money if there are workarounds.
Any guidance is appreciated.
Many thanks!
1996 Volvo 850 (Base) High Mount Brake Light Topic is solved
454cid
- Year and Model: 1996 850
- Has thanked: 151 times
- Been thanked: 139 times
Mine seems to have a loose connection, but I have yet to investigate it.
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
1999 Chevrolet K3500
1969 Buick LeSabre Custom 400
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
jotoya
- Has thanked: 6 times
- Been thanked: 6 times
Update:
But first - want to say how thankful I am that this site exists. I am resurrecting my 96 850 and again, very thankful for the assistance I've received.
As it relates to the update - I ended up unplugging the two connectors at the bottom and sliding out the whole assembly. I cleaned all connectors, used a fresh bulb and dialectic grease. I used a long breaker bar to press the brake pedal while I reassembled the unit. Upon reassembly and before I slid the unit back against the window, the light, once again, was coming on/off intermittently.
As I was about to give up for the afternoon, I decided to finish the reassembly and slide the unit back. All of a sudden, I happen to press the whole unit downward and the light came on. I started fiddling with it by gently pressing the whole unit up/down/side-to-side and finally, as I was sliding the unit towards the window, it "clicked" and the light stayed on and has worked for the last 24-hours - that includes lots of city driving and going through bumps.
This may or may not help someone else but at least it's another troubleshooting angle to work with.
