Hello, I have my 1990 240 that I bought new. I upgraded the ECU years ago from the bad 556. I have replaced injectors, MAF, all vacuum lines, TPS, IAC, Temp Sensors, Oxy Sensor and other things. I do have a VX camshaft that I put in 20 years ago. My car idles a little rough but it will run pretty good and then it will just bog down when accelerating. When it is cold outside (below 55) it barely runs until it warms up. I do have a cold start injector that I confirmed works. I can live with the rough idle but the bogging down is driving me crazy. It will then catch up and take off.
At this point the only thing to replace is the ECU. Any ideas or does anyone have one they would sell? I appreciate any help.
I have tried everything- does anyone have an ECU they would sell? 1990 240DL
- Has thanked: 987 times
- Been thanked: 1075 times
Are you certain you do not have vacuum leak? Perhaps at the intake manifold gasket?
rice240
- Year and Model: 90 240 and 94 850T
- Has thanked: 1 time
Well, I just had the manifold off and actually cleaned and polished it. I replaced several of the hoses like the ones to the IAC. I installed new gaskets. The vacuum did go up a little to about 16 at idle. (I have a gauge in the dash.) I put silicone grease around the new injectors. My flex hose is good. I put a new hose to brake booster. PCV was cleaned and hoses seemed tight.
- 16 Replies
- 3599 Views
Last post by MadeInJapan
- 18 Replies
- 5118 Views
Last post by difflock54
- 1343 Views
Last post by vjaneczko
- 1419 Views
Last post by cuhfs
- 2421 Views
Last post by MoVolvos
