So my 08 s60 periodically feels like the brakes are not locking up. I cannot get ABS to activate on hard braking as the wheels will not lock up when its dry out. It still brakes well, however i am unsure if the system has air in it or some other issue. Sometimes in the rain it feels like the pedal has resistance mid travel and takes longer to stop.
The feeling is more like the wheels slow down to a stop as opposed to a full lock up. This feeling occurs when you fully depress the pedal at approximately 40kmh. Other japanese makes I have driven will fully lock up the wheels and activate abs on rapid braking.
The answers i am searching for are the following:
-does your car lock up when braking hard
-will said lockup consistently activate the ABS module
-does your pedal ever feel stiff while braking.
Thanks
Brake feeling survey for P2 cars
yanga001
- Has thanked: 62 times
- Been thanked: 115 times
2008 S60 2.5T Auto (Sold)
dikidera
- Year and Model: S60 2005
- Has thanked: 68 times
- Been thanked: 187 times
I have observed mine making a horrible grinding sound with a metal knock when I press hard. But mine also does feel like mid travel it isn't locking up as well as it should.
- Has thanked: 987 times
- Been thanked: 1076 times
My 2001 V70 seems to always have a soft pedal feel, but stops very well on wet or dry pavement. I think with later generations of ABS you will not feel a pulsing in the brake pedal when ABS is working and you will never lock the wheels.
- br0dy519
- Year and Model: 2004 XC70
- Has thanked: 132 times
- Been thanked: 126 times
Thisdikidera wrote: 28 Nov 2024, 13:20 I have observed mine making a horrible grinding sound with a metal knock when I press hard. But mine also does feel like mid travel it isn't locking up as well as it should.
04s60 2.4
04xc70 2.5t
04xc70 2.5t
- Has thanked: 2205 times
The 06 XC70 has a nice weighted solid pedal feel. The 02 XC70 has a soft pedal with a long travel, but work well otherwise. Fluid has been flushed and pressure bled and they were the same afterwards.
Neil
Neil
