Have an 07 XC70 (B5254T2, miles 205k) that needs valve work due to PCV banjo bolt failure.
I can source locally a head from 06 R (B5254T4, miles 130k, valve job done at 80k).
Is the 06 R head a direct bolt on for the 07 XC70 LPT engine?
options i am considering
(1) swap a couple valves from the R head into the XC70 head (would get machine shop to replace the valve stem seals too)?
(2) get machine shop to replace the valve stem seals in the R head and use that one
(3) keep looking for valves somewhere else, for the XC70 head
I don't have a price on the R head but he says he'll let it go for cheap.
What would you do, any opinions/knowledge?
head swap compatibility 07 XC70
- Has thanked: 311 times
- Been thanked: 817 times
- Has thanked: 2199 times
- Been thanked: 1851 times
Are the R valves the same size as the XC70. Different power outputs so the R may have larger valves. As to if the R head will work I don't have any idea.
Same valves.
Sounds like the head would swap well, but would want to keep the R cams e.g. https://www.swedespeed.com/threads/b525 ... al.478137/
Well, like having more power is a bad thing..........!
