Spare wheel loose but screwed in tight. 2014 XC90 R-Design
perryleewhite
Year and Model: 2014
Post by perryleewhite »
Checked tightness from above and very tight. Tried tightening the nut below and is it very tight. However the spare wheel/tire is loose and wobbles around and can be heard over bumps making noise. Is there a missing bushing or spacer needed where the bracket touches the spare wheel center? Is there a workaround?
lrock
Year and Model: 2001 v70 xc
Has thanked: 9 times
Been thanked: 37 times
Post by lrock »
this is what vida shows
chitownV
Year and Model: 2008 XC90 3.2
Has thanked: 15 times
Been thanked: 40 times
Post by chitownV »
Have you checked the tire pressure? Read the tire as it’s higher than the regular tires. Especially when it gets colder, the tire pressure will drop and the spare will move.
Good luck
2008 XC90 3.2 AWD - 169k miles, Premium, Versatility 7 passenger, Climate, Convenience, retrofit Morimoto D2S HID bi-xenon, iPd swaybars & poly bushing inserts, Powerflex poly control arm bushings, Bilstein Touring Fr struts, Continental CrossContact LX25 255/55R18, Fr Infinity tweeters & speakers, hardwired cheap $17 Bluetooth to center console aux & pwr, CQuartz UK 3.0 ceramic coated, no oil consumption using Mobil 1 0W-40 even w/ my lead foot
