2005 V50 2.4i very slow starter
Faust
Year and Model: xc70 2008
Has thanked: 31 times
Been thanked: 10 times
Post by Faust »
I cannot get better that a very slow cranking speed, even with jumper cables. Since it does crank, I am not assuming a bad starter. Am I wrong, any suggestions?
2004 V70
1964 Plymouth Convert (small block)
1967 Dodge Coronet (big block)
Year and Model: 2001 V70
Has thanked: 987 times
Been thanked: 1075 times
Post by volvolugnut »
Check voltage directly at the starter connections while cranking. This will tell if you have large voltage drop through power or ground cables to the starter. If large voltage drop, then test each cable for voltage drop under loaded conditions.
While you are checking, test resting battery voltage at the battery studs - not on the connecting cables. You should have about 12.4 volts. Much less and the battery has low charge.
Has thanked: 2197 times
Been thanked: 1850 times
What mileage is on the car?
Krons
Year and Model: 08S60 05XC90 02S60
Has thanked: 198 times
Been thanked: 215 times
Post by Krons »
I’ve replaced two 2.5T starters and on both starting speed was quite a bit faster with new units (One Napa, one Carquest). Pretty easy to change on the Volvo I5 too.
08 C702.5T (sold)
The non-Swedes:
