Release for fuel fill door
- Sveedy
- Has thanked: 445 times
- Been thanked: 479 times
So is there a back-up one for the '99 V70 ? There is no battery in the $100 project car, and I took out the rear side panel looking for the wire hoop, but nothing was there. All sealed up from the inside.
1999 V70 GLT
1999 V70 GLT
- Has thanked: 2199 times
Nope is the simple answer. There was not one fitted to the S/V70 to my knowledge. I did fit one to a 98 from a 850 with a small amount of mods due to an intermittent issue. Naturally the problem fixed itself!
I don't think there is a way to get into it to release it easily but you can get to it with a bit of stretching. You might be able to pull the actuator to release it. Otherwise you will have to break the clip. Can't you hook up jumper cables to it or a jump pack?
I think the clip is $2
It does offend my sensibilities , but the last time I had a stuck one, I broke the clip.
- Sveedy
Well so much is missing from under the hood that I'm a bit concerned hooking up a battery, but I'll give it a try.
I like the idea of retro fitting some sort of mechanical release, so I'll look into that. Just in case...
1999 V70 GLT
1999 V70 GLT
- misha
- Has thanked: 155 times
- Been thanked: 432 times
Doesn't it have an emergency handle in the trunk like 850 wagon have?
It's well hidden...right floor and a little piece of side panel needs to be removed to access it.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- Sveedy
There is no back-up release. I removed the rear side panels and nothing.
But I took jumper cables and fired up the electrical system. Everything, including the filler door worked.
1999 V70 GLT
1999 V70 GLT
Not on a V/S70. I transferred one from an 850 for the lady owner of a 98 V70 as the lock was not always working when really cold. Usually when her car was running on fumes!
454cid
- Year and Model: 1996 850
- Has thanked: 151 times
- Been thanked: 139 times
When I had my S70, the trunk side panel was pulled out, at the top, and I simply would reach in, and pull the electric actuator by hand... EVERY fill up.
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
1999 Chevrolet K3500
1969 Buick LeSabre Custom 400
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
- 2068 Views
Last post by polskamafia mjl
- 2867 Views
Last post by Archer
- 3874 Views
Last post by Blacklab467
- 1544 Views
Last post by Dan McBoost
- 18742 Views
Last post by krenekj
