What are part # for these?
I allready looked about Corteco & Victor Reinz and it seems that both are the same.
I'm talking about the ones behing cam position sensor and the one behind distributor cap & rotor.
https://www.autodoc.co.uk/reinz/7444259
Rear cam seals
- misha
- Has thanked: 155 times
- Been thanked: 432 times
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- misha
Ok...are they the same...behind cam position sensor and behind cap & rotor?
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- Clemens
- Has thanked: 500 times
- Been thanked: 228 times
I'm pretty sure they are the same. will try to take a look in parts stash tomorrow.
still available through Volvo, I got 4 a few months ago.
1996 855 R,
2010 V70 D5,
2010 V70 D5,
- misha
Volvo OE is made by Corteco,Victor Reinz is also a premium choice.
I'll see what i can get.
The one behind cam position sensor appears to start failing.Still no oil dripping but a bit greasy at the back side of sensor.
I hope it's not a valve cover....i need to inspect that area more carefully.
If it proves that seal is bad...i think that the one behind cap & rotor is not far from failing in near future.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- Has thanked: 312 times
- Been thanked: 818 times
I've done a lot of these on P80 cars: both rear cam seals are the same part number, intake (under cap) and exhaust (under cam sensor).
coop
- Year and Model: 1998 s70 t5
- Has thanked: 17 times
- Been thanked: 15 times
Yes. On the right side of the engine Both are the same part number.misha wrote: 15 Dec 2024, 12:21 Ok...are they the same...behind cam position sensor and behind cap & rotor?
I switched out cap/plug/wires on one side and the camshaft position sensor on the other when I did them
- misha
I got Corteco...rear cam seals replacement went well and smooth... thanks to cn90 write-up:
viewtopic.php?t=50752
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
