Fuel Injectors not working
toatesarchitecture
Year and Model: 1998 V70 T
Has thanked: 1 time
Post by toatesarchitecture »
Hi - I've got a project car and there is an injector problem. When I test the injectors with 12v they all work, But when I crank the engine, they dont. Also even with new fuel relay, fuel pump only runs when I use jumper on relay power. Thoughts?
I checked all fuses.
jreed
Has thanked: 384 times
Been thanked: 221 times
Post by jreed »
When you turn the ignition key to the run position with the fuel pump relay installed, can you hear the fuel pump run for a couple of seconds or so and then shut off? If so, my understanding is that this is normal -- the fuel pump relay only allows the fuel pump to run for a couple of seconds if the ignition signal is missing.
toatesarchitecture
Has thanked: 1 time
fuel pump does not run at all with relay installed - new relay, but runs with jumper
jreed
Post by jreed »
I've got a '97 850 and haven't worked on V70's so I could be wrong, but I would suspect that the fuel pump relay is not good if the pump doesn't run/prime for a few seconds initially.
I'm not sure what would cause the injectors not to work, but I've read that a faulty camshaft position sensor is one potential cause to check. I replaced mine a few years ago and I was surprised how crumbly the original connector was... the plastic just fell apart when I unplugged it.
Has thanked: 1611 times
Been thanked: 4072 times
The fuel pump relay gets activated on key on, do you hear the pump whir for a second or two?
After starting, the relay has to receive a 40Hz? Signal ftom the engine to stay on.
If this car has never started you have to confirm the immobiliser is working, VIDA IS best for this
